nx 9 visulation issue
suyog21
Automotive
IN
Not able to see round objects round, theys show polygon. And section curves deviate from section surfaces.[pre][/pre]
Suyog Patil
CAD Enginer
NX 7.5. 8, 8.5 9, 10 TC-9
It's "as designed" ,Personally I hate it. I work on small assemblies and tooling.
There is a document explaining it here: link
You'll need Webkey access to view it.
This very cumbersome, as while dmu analysis we check by putting section and and section doenot match the face. It has been given one false result and we changed part. We had hamperwd our delivery date for same.
Also section section does not update while drading, they update when we stop dragging.
There is no need of so many option in section display menu.
Suyog Patil
CAD Enginer
This behavior is there to provide improved graphical performance, particularly with large models, however, this can be controlled by the user. If you're talking about Components in an Assembly, simply toggle OFF the 'Use Lightweight Representations' option on the 'Assembly Load Option' dialog. If you're talking about how piece parts look, then go to...
Preferences -> Visualization -> Faceting
...and in the 'Part Settings' section for 'Shaded Views' set the 'Facet Scale' option to 'View' and then set whatever level of 'Resolution' you feel is needed to give you the results you desire.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
As suggested by John i did same thing yet I have to updisplay continously when i zoom in small area for checking.
Suyog Patil
CAD Enginer
Then try using the 'Fixed' option for the 'Facet Scale'. That way it will not depend on whether you're zoomed in or not as the display will be unaffected by the scale of your view.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Sometimes "fixed" helps. other times you still have to update display or even regenerate.
its a major inconvenience for those of us who work on "smaller" models and assemblies.
I've tried to make a journal but those settings are not supported
