bassplaya69er
- Dec 28, 2011
- 11
Hi There,
I have recently started trying to use FBM in NX cam to program wooden parts such as:
this is just a test part, Product parts are much larger and more complicated. as the Blend is manufactured using a round over, user defined tool, i am currently using a planer profile operation and selecting lines / curves of the part to define the tool path. - which on a larger part takes ages and a lot of these parts are one offs.
the Feature detection appears to work fine :
then i program one feature using planer mill operation & user defined tool :
when i try to teach operation i get this error:
WARNING: Type clash: PocketMilling.Region_Connection: Boolean (false=0,true=1) = Tma.Integer[4]
ERROR: Unknown class: 'MILL_ORIENT' (Geometry Type)
ERROR: Unknown class: 'EngageRetract_?' (NCM Type
i have read the manual's and it seems that i may need to use the MKE and manually edit things, its just not very clear about what i need to edit.
if anyone who has experience with FBM / MKE could give me some help that would be great.
thanks in advance
Matt
thanks in advance
Matt
