NX 8.5 Sketch - Dimension Options - Midpoint
ARToolingEngineer
Aerospace
Greetings,
I've used later versions of NX before, and while in sketch, and dimensioning, I was always able to select a midpoint of a line and dimension it to something. With NX8.5, midpoint is not even an option with my current set-up. Is this an option to make available?
Thanks,
Brent
The midpoint constraint should be in there someplace.
When you are in your sketch go to your command finder and enter MIDPOINT. When it comes up you can right click on it and add it to a menu bar.
Jerry J.
UGV5-NX1961
Hi Jerry - Thank you or the reply. I did look for where to add snap features, but am unable to find it. When I search for the command button, it only allows me to add midpoint for anything but in Sketch mode. Could you give me a little more boost?
Thanks,
Brent
