NX 12 | working in an assembly but with an individual work part
BurgerMechE
Automotive
Oct 20, 2014
13
So we just did a massive upgrade (if you'll call it that) from NX8.5 to NX 12. There must be a setting which I can't find but my problem is this... I have an assembly open with many parts in it. I make a component the work part. I edit a sketch or even create a new sketch in that part, all the dimensions I create are locked in place and I can't drag them. I can open that part in a new window and all of a sudden the dimensions can be drug around. Go back into the assembly, work with the component as the work part and the dims are locked. Is there a setting to make it so the dimensions can be moved around? Thanks!
NX 12, windows 10
That seems like a bug to me. I suggest to report it at GTac (could not find an existing IR)
Which version of NX12 are you using? NX12, 12.0.1 or 12.0.2?
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
Have you checked your layer settings by chance?
Tim Flater
NX Designer
NX 11.0.1.11 MP8
GM GPDL 11-A.3.3
Win7 Enterprise x64 SP1
Intel Core i7 2.5GHz 16GB RAM
4GB NVIDIA Quadro K3100M
