NX 10 solid body with openings
shidinghao
33
Hi
I imported a model, which was created on Rhino, to my NX10, there are big holes on it. However, the wired thing is it's still a solid body, not a sheet body. when I see it from a section view, it's solid. So I tried to patch the opening using "through curve mesh",I end up getting a sheet body and a solid body, but I don't know how to combine them? Or if you have a better way to fix the openings? Please let me know.Attached is the model.
Thanks.
 http://files.engineering.com/getfile.aspx?folder=0c592f0b-3a25-4e79-917d-2e2fb901e58d&file=remote_strip.stp
I Would say, just trim the body in half and mirror it...Easiest way to fix this...
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
