NURBS question
BodyBagger
Hello all,
I need to D/L a model but it is a NURBS format. After the download I will need to modify it (add some holes, insert into an assembly, stretch it a bit, etc.) Will I be able to do all of this with a NURBS model? Can i convert it to a STEP? I ask all of this because I have to buy the download and I can not afford to waste the cash.
Thanks,
BB
What is the extensions available? Once in SolidWorks adding holes and inserting it into an assembly will be no problem. The stretching could be performed by scaling in 1 direction or by deform, warp, freeform etc. I hope this helps.
Rob Stupplebeen
Hi Rod,
The extension is .IGES
SolidWorks can open the file then. After that save it as a sldprt make your changes then export in any format you like such as STEP. I hope this helps.
Rob Stupplebeen
Hi Rob, thanks for your input.
