I have a book on hydraulic systems ("IPT's Industrial Hydraulics Handbook"
that refers to NPTF as:
"A variation of the NPT thread that is used for hydraulic purposes is the Dryseal ANSI Standard Taper Pipe Thread (NPTF). This thread has the same form and dimensions as the NPT thread, except that the truncation of the crests and roots is changed to ensure that the spiral clearance around the thread is eliminated.
THIS THREAD MAY ALSO BE REFERRED TO AS THE NATIONAL PIPE TAPERED THREAD FOR FUELS.
The interference at the crest and root of the mating parts of this thread eliminates the need for a sealant to seal any clearances. Be aware that assembling any thread system without lubrication can lead to galling, expecially with materials such as stainless steel or other nickel alloys. A thread sealant should be used with this thread for anti-galling purposes."
The information on the drawing you're looking at could mean either female national pipe thread, or dryseal. I'd make a phone call to whoever did the design, just to be sure what he meant.
The book goes on to say that special taps and dies are needed to cut this kind of thread, and unless specially marked, you can't really tell NPTF from NPT, just by looking at it.
