I have always been taught that backwelding threaded pipe actually does more harm than good. If you cut and make the threads per ASME B1.20.1, then back welding should not be required. The theory I was told was that the welding just creates a heat affected zone and you end up with lower strenght of the pipe and joint.
Is it good engineering practice to not backweld or good engineering practice to backweld 2" pipe in natural gas service?
