I was hoping someone on this forum may help with a question I have.
I have a condenser that runs off into a flash vessel. The vapour then goes off to a vacuum pump and the liquid to a gear pump. The flash vessel runs at 0.4bar and the vapour pressure of the solvent is 0.04bar.
The question is, how to calculate the NPSHa for the gear pump.
Should I just take the Vap Pressure of the solvent (0.04bar) or is the pressure in the vessel equal to the Vap Press.
Thanks for your help.
