charmquark
Chemical
Mcnally institute gives a bunch of examples regarding calculating NPSH.
The example I had a question regards the vacuum tank example.
The example states the tank is under -20 inches of mercury vacuum (-22.7 ft head).
Thus the absolute pressure in the tank is 34-22.7= 11.3 ft
The fluid in the tank (water) is given as 180 deg F with a vapor pressure of 16.7 ft of head.
The vapor pressure of the fluid is higher than that of the pressure in the tank. Shouldn't the fluid be boiling/flashing in this case? If so why doesn't the fluid vapor pressure and tank pressure reach an equillibrium? With either the fluid cooling down as it flashes and/or the vacuum in the tank decreasing?
