might have better luck posting this in "Engine and Fuel Engineering" on this site.
I beleive the answer will depend on what you modify to reduce NOx.
If you add a DPF and SCR (not likely w/HFO & sulfur), the backpressure will hurt your exh. temps and fuel economy
If you retard timing, you'll hurt fuel economy
if you're injecting water, I dunno.
