Ron247
- Jan 18, 2019
- 1,166
I decided to make a standard note for field measurements. I do a lot of this at times and felt a single general note would be helpful. Here is a rough draft. Note #1 is the more common one I see and have used but I have found when others field measure they tend to not think of all the things that are not perfect. Whenever, they get it wrong, they look to my drawings and try to blame it on me. I had someone today who was off by 4" in trying to determine if a masonry block was 8" or 12". He looked at the corner and saw there was 4" from the inside face of one wall to a mortar joint on the intersecting wall. Good old mathematics. 12"-8" = 4". So he deduced this was a 12" block meeting an 8" block. No, it was the long dimension of a 16" long block meeting a 12" block. 4" is also equal to 16-12. I noticed what he was doing and told him it was a 12" block. I know because I had drilled a hole in the wall earlier and checked it. Comments on the note?
