Noob: Converting part to sheet metal
  • Thread starter Thread starter BFresh
  • Start date Start date
B
BFresh
Guest
I'm struggling to convert a part to sheet metal so I can save it to DXF for laser cutting.
The part is downloadable via this dropbox link. https://www.dropbox.com/s/yn90z2ue7aqeshy/HT Gusset.sldprt
Its derived for a split part, which was modified, and then split again.
I've read various posts and articles but keep getting stuck. I have about 15 more parts like this to convert. I've tried but I've not used sheet metal feature on solidworks before.
Hi, any chance you could upload the part as an IGES file. I'm using ProE in work but can hopefully tell from looking at the geometry why it's not converting.
Michael
This part can't be converted to sheetmatel due to the eliptical cut feature and the varable bend radius of the part. The best thing to do is create another base flange starting at on end and adding edge flanges one at a time by approximating the length, angle, and radius for each segment of the curve. Then re-create the elpitical cut and add the tabs.
