I have a single cable with 24vdc pos/neg within that switches a load of approx 200ma. Is it possible to determine when that line is active (switched on and running the load) by any noninvasive means currently available? Whether Hall Effect or other transducer/transformer?
Ideally, I'd like to be able to monitor such a line for on/off status without having to open the line and separate the conductors. I've been told that this is impossible - that any (noninvasive) attempt to detect a load will be cancelled out by the balanced lines.
Is this true?
Is this true?
