I'm currently looking for a non-return valve to be used as a security on a truck air line.
Air line specs:
inner Ø4mm, max air pressure = 12bars, max flow = 30l/min.
The valve must allow any air flow and retain any back flow.
This back flow may contain urea (Adblue).
I've followed the lead of automotive fuel/vapor lines but I haven't found anything regarding check valves.
The best would be to implement this check valve in a fitting meeting the SAE J2044 standards. Does somebody know these kinds of products?
Help would be very much appreciated.
Thanks.
Air line specs:
Thanks.
