Non metallic rebar
trashcanman
470
Just curious. Do any of you use non-metallic rebar for reinforced concrete? Seems like a good idea to avoid corrosion and failure. What kind and does it work? Thanks.
That's part of the disguise. Batman has his seal. Bruce Wayne is just a regular old joe.
jayrod12 said:
I took the long route and fought it out with the local Uni.
Probably for the best in the long run. The transition nonsense was goofy, painful, and ineffective as education. I should have done UBC.
I feel that Batman would be designing cable stayed bridges and glass vehicular bridges without a seal. He's extra-legal / maverick. That's how Batman rolls. With a seal, he's just a sad keener like superman.
I would avoid polypropylene fibres... they are not reinforcing!
Dik
Teh... I think there are more cost effective ways to minimise crack control than using plastic fibres... quit using fibres a couple of decades back. If you ever try a shovel into a batch... they're a lot more work for any benefit gained.
Dik
