aniket79
- Aug 11, 2010
- 6
hello everyone,
Currently, I am working on Plain channel section having dimensions 180 mm length, 60 mm web x 30 mm flange and 1.1 mm thickness. I have generated codes for axis symmetrical section for analysis but whenever I am running those codes, ANSYS gives me warning message (Non-linear buckling analysis) “Both solid model and finite element model boundary conditions have been applied to this model. As solid loads are transferred to the nodes or elements, they can overwrite directly applied loads”. After few minutes solution gets converged. But results obtained are different from my theoretically calculated results. results differ by 50% in ANSYS and calculated.
it would be great if any on help me out...
thanks a lot
aniket
thanks a lot
aniket
