Here's a puzzler for you guys. It has me stumped at the moment.
I have a prototype circuit, real pcb, on which I have a Caddock MP2060 non-inductive resistor of 0.05 ohms. I was trying to use it for current sensing. However, the voltage produced across it doesn't match the current measured with either of two different types of Tektronix current probes. I believe the waveform, as displayed from the Tek probes, based on an analysis of the circuit involved.
Using one of HP's best LCR meters indicates an inductance of 35 nano-henries and a capacitance of 5 pF.
The real current waveform should look like a sawtooth. It does from the Tek probes. The voltage waveform looks like the lower 20% and the higher 20% of the waveform is a sinewave. So, only about 60% of the waveform is correct.
The switching frequency of the current is 20 KHz.
For 2 points, tell me what is going on here.
