I've been searching the Internets for the past few days trying to find an answer to my question to no avail. There is a similar thread on the forum here I found yesterday ( i cant seem to find it today) but it doesn't quite pertain to my dilemma. I've gotten in contact with the Representative from the Office of the State Fire Marshal and have gotten a, seemingly typical, boilerplate answer of "If the vessel is operated at or below 15 psi, the vessel is exempt from State of Illinois Inspections." So, alas, I am here to see if you fine gentlemen will help me.
We have a vessel that has a Flanged Head (with 1" Internal Coils for Condensing) that needs replaced because of corrosion found recently. It will be "Replace-In-Kind" but using the latest edition of the ASME Sect.VIII code. Please see vessel information below.
Questions:
1. Should this head be fabricated IAW Sect. VIII / NB-23 and be documented on an R-3 Form?
2. Should this head be fabricated IAW Sect. VIII and have a (PRT) U stamp?
3. Should this head be fabricated IAW Sect. VIII and have a U stamp?
4. Does this even need to have any involvement with State or National Board? ie Just fabricate it using ASME Sect.VIII code and have one of our in-house Inspectors make sure it is done correctly.
The predicament we are in: We have a Vessel that has a design pressure of 50psig that has no stamp, that operates in Illinois. Okay no big deal with the grandfathering and state special loopholes. But, now we need a new head and it is to be RIK.
-The vessel that the New Head will be bolted to, is not Stamped and operates under 15psig. But, the New Head will have a Design pressure of 50psig. If we decide to increase our operating pressure above 15psig, it will need to be "okayed" by the State in order for operation to commence. If it is not stamped, is this going to be an issue?
Built: 1991
Design Pressure: Full Vacuum - 50psig @650F
Coil Design Pressure: 150psig
Operating Pressure: Vacuum - 5psig
Design Code: ASME Sect.VIII
ASME Stamp: No
U-Stamp: No
Service: Non-Lethal
Questions:
Built: 1991
ASME Stamp: No
U-Stamp: No
Service: Non-Lethal
