Nodal stress history output
pfsm01
12
Hello all,
I am trying to obtain the stress history output of a node in my model. To do this I went into the Step module -> Tools menu -> Set -> Create -> Node, and selected the desired node.
I then went to the Output menu -> History Output Requests -> Create -> Set, and select the set I just created. I then selected the stresses as the output.
However, after I run the analysis and go into the Results menu -> History Output, the stress data is nowhere to be found in the output list.
Am I missing a step here?
Thanks for any help,
pfsm01
Why do you need stress data as a history output? Default options provide stress data as a field output anyway.
Open your INP, scroll down to the OUTPUT REQUESTS, and put the following in your INP:
Code:
** OUTPUT REQUESTS
** FIELD OUTPUT: F-Output-1
*Output, field
*Node Output
U, RF
*Element Output
S
** HISTORY OUTPUT: H-Output-1
*Output, history
*Node Output, nset=myNodeSet
RF2, U2
*End Step
Note that myNodeSet is the name that you provide to the node set of your interest.
