slickdeals
- Apr 8, 2006
- 2,267
Folks,
I am having a discussion with one of my senior engineers regarding the attachment of a nodal brace for a column.
The nodal brace is designed for 1% of the compression load on the column and meets the axial stiffness requirements.
My question is thus:
Does the connection from the column web to the bracing beam need to be a slip critical connection or can it be a bearing type connection with fully tightened bolts?
Even though the standard holes only have a hole diameter of 1/16 more than the bolt diameter, I am questioning whether things will be fine in the period between when the column goes into compression and then eventually into bearing at the brace?
