Dear Colleagues,
I am now working on a 3-effect evaporator in my plant. The evaporator is mainly composed of 3 flash drums, 3 heat exchangers, and 1 final condenser.
Steam and Vapor flow direction: steam from other production process goes to the 1st effect heat exchanger; the vapor from 1st flash drum goes to the 2nd effect heat exchanger; the vapor from 2nd flash drum goes to the 3rd effect heat exchanger; and the vapor from the 3rd flash drum goes to the final condenser.
Feed direction: the feed goes to the 3rd effect heat exchanger; then 2nd; and at last to the 1st effect heat exchanger. From the 1st effect heat exchanger, the feed is pumped into final product bin.
The 3-effect evaporator is using a 2-stage ejector to vent remaining vapor/steam to the ejector itself condenser through vent lines connecting the 3 heat exchangers and the ejector, and then discharge them to the atmosphere.
The problem I am facing is that there is no vacuum in all the 3 flash drums (According to the design, the drums are supposed to have vacuums in them). I am wondering: what should result in vacuums in the 3 flash drums? The vacuums in the flash drums are generated by the 2-stage ejector? Or, the vapor condensation process in the 2nd and 3rd heat exchangers and the final condenser causes the vacuums in the drums?
Any one can recommend me some books about multiple effect evaporators?
Thanks for your time and help in advance.
Sincerely.
Sincerely.
