On this new build yacht i work on there is not going to be any ground fault indicator installed, we have got a 400v 3 phase 4 wire system with neutral connected to ground. The explanations i got was that i dont need any indications beacause if i have any earth leak over 10 amps the breaker will trip and therfore no damage will be done,
But what if i have many small leakages less than 10 amps?
Won't this be bad for the yachts hull? Paint,Anodes
How can earth be connected with neutral together?
Thanks for the help.
Adam
Adam
