Nitrogen psychrometrics
PlantEng
15
I am looking for properties of nitrogen and water vapor at pressures up to the 50 psig range for drying gas and convey problems. Does anyone know of a good resource for this data?
Work Around: If you cant find it, try using the water - air psychrometric chart (air is composed of 80% Nitrogen) and depending on the properties for your calculation, correct then based of the compoments (oxygen, nitrogen) properties.
