mfgenggear
Aerospace
- Jan 23, 2008
- 3,472
Does any one have some material that would like to sale. a small amount, like 3' long.
I need to run some Heat Treat(Harden,Temper & Precipitation Harden/Nitride Test.
need to work with my Heat treater on cycle time in hours to obtain .018-.024 effective case depth + grind stock.
if any one has worked with this material recently I would be great full if you could pass on any info on the above & inch per inch change if any during the Nitride cycle.
Thanks & Kind Regards.
Mfgenggear
Mfgenggear
