"Didn't mean to nit-pick on the original post. It seemed like your subject line raised q question of contrast between FFT and DFT that wasn't discussed in the link."
No, I just liked the article. No nitpicking. (I'm biased, I know the author- he has a good solid background in signal analysis)
""the DFT and the FFT of the same sampled data are identical". I'm not sure I get it. Sounds like you're saying the same thing as me. "
Well it all depends on when you sample - an FFT has built-in limits , whereas a DFT doesn't. That is, you can give me a DFT for every FFT, I can't give you an FFT for every DFT.
Now, what really interests me is that the FFT terms were non symmetric about the centrally placed signal. Weren't they?
Cheers
Greg Locock
