There are three main categories of sprinkler systems.
1. Low pressure system – conventional watersprinkler system.
Working-pressure below 10 bars. A certain type, called Mist Waterspray System, can be identified in this group.
This type of systems has at least 70-80 % water consumption compared to the conventional watersprinkler system.
2. Medium pressure system – mist waterspray system or watermist system.
The pressure range is from 10 up to 40 bars. The water consumption is at least
50-70 % of the conventional watersprinkler system.
3. Highpressure system – watermist or waterfog system.
The pressure range is working from 40 bars up to 100/150/200 bars.
The difference between mist and fog is the size of the droplets.
Fog has in average smaller droplets than mist.
A highpressure waterfog system has advantages over the low- and medium pressure systems
Total weight and the amount of water is reduced to a minimum.
Cooling effect is extreme high.
The grade of heat expansion.
Sizes of drain and scupper system is reduced to a minimum.
Dimension of pipes is small.
Services | Contact Us | Sprinkler Systems | Manufacturers List | Safety Equipment
Add Coastal Fire ™ to your favorites!
GLOAL CORPORATE OFFICES
INFO@COASTALFIRE.COM
Phone (504)-488-1212
fax (504)-488-8847
8201 Peach St.
New Orleans, LA 70118 USA
Texas Office 2860 Antoine Road Houston Texas 77092 USA
1-800-353-1652
JOHN HEYWOOD, P.E., CSP
SENIOR SAFETY ENGINEER
Saint Louis, Missouri 63125
