NFPA 68
nuche1973
300
NFPA 68 gives a maximum mass for vent panels as 40 kg/m^2. I am not sure if this is meant to be 40 kg(force)/m^2 or if I need to multiply the number by the acceleration due to gravity. I am designing a vent panel and am having trouble deciphering what is required by the code. I am working in Imperial Units and this value is my limiting factor. Any suggestions, clarifications would be appreciated.
Convert from weight in lbs. by dividing it by 2.205 to get kg.
So, then NFPA is talking about kg(force) and we are converting it to pound (avoirdupois), correct? Or do I need to consider the definitions given for Newtons and gravational mass?
There is no such thing as kg(force). The kg is a unit of mass.
Not in SI correct, but is used. I just needed a clarification in how NFPA uses it.
Your original post says mass is 40 kg/m2. There is only one way to interpret that and MintJulep is correct. Why are you confused?
