Gentlemen,
Your assistance would be appreciated please, the above clause in NFPA 20 states that the Jockey Pump stop point should equal the churn pressure of the Pump plus the minimum static supply pressure, I have a 10m High Fire Water Storage Tank, I have an 8" Outlet on the Tank and 8" Inlet on the Pump Suction Flange so there is no difference in heght between the two connections, can I therefore assume that the minimum static pressure available will be zero?? Or do I have to make an allowance for static gain...if so...what would it be and on what basis?
Many thanks.
Many thanks.
