To join sheet bodies use the sew command. If the sheet bodies enclose a volume, a solid is created. If a solid body is your goal you may find it easier to create the solid first and trim it away with your sheet bodies (kind of like sculpting, start with a large block and then create trim tools to get your final shape).
