chrisk201
- May 3, 2006
- 3
I have worked the past ten years as a highway designer for a state agency and my hydraulic design skills have eroded. Our maintenance department wants to extend water and sewer service to one of our rural maintenance facilities and have asked me for design help rather than hiring an outside engineer. The facility is about 2500' from the city limits and the city water system. They would like to use 1500' of 6" PVC to extend to the property line of our facility and then 1000' of 2" to get to the building. I had the hydrant at the end of the line tested and it had a Q of 850 gpm, a pressure of 66 psi and and the next hydrant up the line showed a pressure of 47 psi when the line was flushed.
Given all that, I guess I need to calculate the pressure at the building to show it is greater than 30 psi. Do I just calculate the loss through the pipe network and then the new pressure? I used an online calculator and it showed a major pressure drop and head loss in the 2" section and I think I am doing something wrong. Thanks all for your help.
