New worksheets on my drawing
Morglisn
Industrial
I was hoping someone here might be able to help me out with this, as it's turning into a real time-killer for me.
Our title block for our drawings contains an area that's set aside for details on the part, specifications of a sort. What I'd like to be able to do is keep my sheet format and template notes blank, and fill them out ONCE per job. Is there any way to add a sheet to a drawing, and have the modified sheet format on Sheet1 copied to Sheet2?
I know my explanation is a bit mangled, I'm hurrying. Thanks in advance for any help/advice.
Ah, one more thing. We'd rather not clutter up our hard drive space by creating a new template/format for each set of drawings. We were hoping to just use the blank as our template.
I do this by saving the first sheet as a current template.
What I mean by this is that I edit my first sheet to how I would like it, then go to File/Save sheet format and save it as something like Current_Dsize in the Template file.
Then use this template for your additional sheets and edit them accordingly. Whenever I change drawings I just save the current sheet over the template Current_Dsize, it doesn't matter how many times you save over the template.
I hope this is clear.
Another method might be to create a BMP file of your specs. Once this is inserted in a drawing, you have the option to show this on every page. Plus as a BMP, you don't worry about people changing it by accident.
MadMango
"There is no reason anyone would want a computer in their home."
Ken Olson, president, chairman and founder of Digital Equipment Corp., 1977
Have you read faq731-376 to make the best use of Eng-Tips Forums?
Perhaps save those specs into a block definition, and instance that block onto each sheet.
Last I checked, blocks could not be on the format, though. They would need to be on the sheet.
[bat]If the ladies don't find you handsome, they should at least find you handy.[bat]
I use custom properties attached to text (a space as a placeholder) on the formats and templates. When I add sheet 2, properties with the same name as on sheet 1 are filled in with the same information.
Judy Mitten
Aerospace Display Systems, LLC
Hatfield, PA
