new to surface modeling 1
Juleshart19668
Industrial
GB
help I use swx 2008 and i mainly use the sheet metal and weldment tools, a client has given me a IGIS file for a sculpture they want to manufacture - i need help as i need to make detail drawings of the model with dimentions etc but not sure how to procede, cant seem to create a drg then dimention anything??? what am i doing wrong ( i know very little of the surface tools)
thanks in advance
julian
You don't mention what the sculpture is of, but I assume it is of very organic surfaces. It will be very difficult to dimension as a complete surface model.
In what material will the final sculpture be made?
Is the real world sculpture to be created by hand, rapid prototyping, pantographic mill, ???
Creating sections to dimension 'might' help, but could entail too many views.
here is the file, it is to be manufactures from 8mm thk ss and internaly strengthend not certain what methods yet just need to be able to take dims and rads etc so i can work out best way to make it.
thanks
Julian
 http://files.engineering.com/getfile.aspx?folder=5c55d87b-9ceb-4d1a-a013-efe00b7fa4bb&file=release-sculpture-160209.igs
Next time try to get a parasolid file. Although the IGS file came in cleanly it was scaled 1:50.8
How many pieces are required?
Are you making this yourself, subbing out, or just consulting?
If yourself, what equipment do you have to cut and manipulate 8mm SS?
I think if you rename the standard Front view as the Top, you can then bring the model into a drawing. Looks like the edge with the sharp edge would be the bottom to me. You should be able to pull dims from Point to Point. If you want, you could create a sketch line at the bottom of the part and dim to that. I think this is going to be hard to pull any useful dims from this since there are no flat surfaces except the bottom. I would use coordinate dims to plot the tangents of the various radii.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read faq731-376 to make the best use of these Forums?
the model is actual size as in aprox 12 metres tall and with a wall thickness of aprox 400mm the client wants it skined with 8mm ss plate and is to be manufactured in china?? what they require is me to make drg's with enought info from that igis file (flat patterns, dims etc)for them to sub it to prob the cheapest bidder. as i said i use solidworks on a daily basis for sheet metal work and this surface modeling is very new to me.
Creating a skin is easy. Simply Ctrl select whichever surfaces you want combined as one piece/panel, then use the Offset Surface tool (surfaces toolbar) and use a zero offset. Select the newly created surface and use the Thicken tool (features toolbar) to thicken to 8mm.
What material is the base sculpture?
Is it being manufactured in China also? Same place?
