I've worked for a geotechnical firm for 5 years and now im suddently working for a municipality and getting caught up to speed on storm water design.
I'm still trying ot get clear in my head the basic methodologies involved with designing a storm water conveyance and detention system.
We have some basic criteria that specify using the rational method for sites under 10 acres with a Tc less than 15 minutes, and using TR-55 for bigger sites.
My confusion is understanding what is meant by 'The Rational Method'. All I have seen, indicates that the Rational Method involves applying the equation Q=CiA to calculate peak flow rates... but what do you do with that peak flow rate? the Rational Method doesnt appear to encompass a procedure for creating a hydrograph after you have calculated a peak flow rate.
Also, I guess im not sure what procedure TR-55 uses to calculate peak flowrates. I have read that it uses either the 'Tabular Method' or the 'Graphical Peak discharge Method' to calcualte a peak discharge. I have used Win TR-55 but I did not see an option to choose which method it uses.
Win TR-55 will spit out hydrographs too. What procedure does it use to generate a hydrograph? Aren't there several ways to create hydrographs (such as the 'unit hydrograph' method?).
It appears that the Rational Method, Graphical Peak Discharge Method, and the Tabular Method all require the time-of-concentration to be calculated.
After one of these three methods are used to estimate a peak flow rate, another procedure is applied to come up with a hydrograph.
I know there are other program out there that people use and im not sure which procedure those programs use to calculate peak flow rates and to create hydrographs. Some I have heard mention of are Pond Pack, Hydraflow, Hydrocad, and SWMM.
I'm assuming most of these programs use procedures other than the ones ive listed to calculate peak flows and and to create hydrographs?
I guess ive asked enough questions. I appreciate any feedback.
