bicycledisciple
Hello everyone,
This maybe a heat transfer related question as opposed to gas compression but context is within a gas compression application. Requesting some insights from process and/or air cooler specialists.
Consider a new replacement centrifugal machine being installed in an existing plant with all interstage equipment remaining the same. There is an intercooler and a separate aftercoler. Aftercooler has a design limit of 250 F with no tolerance.
Looking for a qualitative understanding of impact to cooler - flows, pressure drop, temperature out etc should the compressor discharge T exceed 250 F. Would there be severe impact to the existing equipment? Process conditions below :
First stage inlet P = 15.7psia
First stage inlet T = 120 F
First stage inlet V = 51535 cfm
First stage discharge P = 164.9psia
First stage discharge T = 324 F
Second stage inlet P = 154.9psia
Second stage inlet T = 140 F
Second stage inlet V = 4329 cfm
Second stage discharge P = 484.7psia
Second stage discharge T = 255.7 F
Thanks.
Thanks.
