cbinstitute
Geotechnical
- Aug 16, 2005
- 4
Hello, I have just been granted a patent on a new rotary engine design but I need help with the seals and lube. I need a material that can be used under high temp and pressure. I would like to get away from using anything petroleum based. I have considered Teflon but I don't think it can withstand temps over 500F. I would like to be able to coat the rotor so there will be and air tight seal with the housing with a low friction coefficient. Any help would be appreciated. Thanks
