greznik91
- Feb 14, 2017
- 186
Greetings,
slab is 200 mm and anchored in the middle. Slab in one way (I cant use walls perpendic. to beams for slab support)
I have a questions:
- is anchoring with rebars ALONE reliable enough to support new RC slab on existing beams? So everything would be depending on shear capacity of anchors and concrete edge.
- Beams are only 200 mm wide. How long should rebars be? Since they act in shear only I think 150 mm anchored in both sides is okey?
- if my solution is not alright, what would you do?
I have a questions:
