rodowd
Automotive
- Jun 29, 2003
- 1
Up front I don't know whether this is your area of expertise. I have a brand new Honda Odyessy, about a month old. I took it to a car wash and a hydralic line broke. It covered the entire car with fluid. They hand washed the car twice and fluid was still dripping out of crevices etc. It is under the car and the entire outer surface, even some is inside the engine compartment. They admitted they didn't have anything that could cut through the oil. They have the car all day today to detail it and remove the fluid.
It is in every nook and cranny, they admitted they will not be able to remove the oil from all crevaces etc. My concerns are:
Will this have any effect on the paint, plastic surfaces and rubber seals?
Over time will the fluid sitting in crevaces have any negative effect?
And most important if this was your car would you feel this incident has devalued the car?
Again I know this is probably not the the normal sort of question you recieve. If you could please give me your best advice or even some referrals as to who I might I contact. I am really sick about this, it is the first new car we have had in 14 years. Thank you very much for your time and any info you can provide.
Thank you,
David Rodowicz
Thank you,
David Rodowicz
