Neutralizing HNO2 and HNO3 with caustic
corrjay
Chemical
Nov 16, 2006
4
Quick question, this may have been posted before, but if I had 12,000 ppm or dissolved nitrate and 300-9000 ppm of dissolved nitrite do you know how much NaOH I would need to try and neutralize it since i have a pH of ~1.9?
Is it almost a 1:1 ratio: i.e. with 5000 ppm nitrite I would need 5000 ppm sodium hydroxide?
This is high school chemistry, which if you are in fact a chemical engineer, or at least a chemist, you should not be asking the question about!
If you wish to simply neutralize the mix, take a reprsentative sample and titrate it with a sodium hydroxide solution to a pH 7. Calculate the amount of sodium hydroxide from the titration required to neutralize the solution.
Orenda
HNO2 and HNO3 are both very strong monovalent acids. If you neutralize them with NaOH there will be no buffer action,the pH at equilibrium =7.You can simply calculate mols of both acids and add the same amount (in mols!) of NaOH.
m777182
To my grasping the answers by orenda1168 and Chembuddy are right. The acidity could be the effect of cations. For example, 0.1 M aqueous solutions of Fe(NO3)3 and NaNO3 at 25 deg C would show pH values of 1.6 and 7.0, respectively. Iron(III) acts as an acid through Fe(H2O)63+.
Yes, ChemBuddy, I am wrong. HNO2 is not as strong as I had in mind and it will make some buffering. So an titration experiment(s) is(are) needed.
Thanks for correcting me.
m777182
