SphincterBoy
Does anyone out there use neutral grounding resistors on the neutral(s) of the distribution substation transformer WYE secondary windings?
I have a situation involving a distribution substation with high ground fault current, in which the electronic feeder protection module (I'll use the acronym POS to describe it) is tripping and going to lockout after one pickup (shot) of a high-magnitude ground fault (undocumented anomoly). I don't want to change the protection module, but I'm exploring using a neutral resistor to lower the fault current to the point where the module will not immediately go to lockout, but reclose (as intended). We have other situations similar to above, but the protection modules will trip/reclose several times trying to free the dead squirrel off the insulator before going to lockout.
I have read that utilities will install neutral resistors to limit ground fault current, and lower nuisance outages.
What is been your experience?
