To satisfy failsafe requirements, I need to provide two springs in case one should fail. Application is compression spring for nominal .25 dia pin. Need to have a 0.4 lb min load (per spring) at 1.25 inch ht. The spring will be compressed down to .83 inch ht where I would like the load there to be as close to the .4 lb as possible (i.e. low rate)
I originally had a single compression spring .240 dia, .018 wire, 2.0 free ht in a .255 hole. Can I simply add a second spring inside of it as long as there is radial clearance between the two on installation? Is this normal practice with no significant chance of interference and malfunction? Since the second spring is completely redundant and only there for backup there would be no sense in this approach for me if nesting two springs causes an overall higher chance of malfunction.
