I have recently stumbled into a problem. I admit that I am no expert on NEMA and or motors, I can control and write the code for one so long as it runs. Here is the prob. I have a 200HP Motor with a 250HP afd on it. The load an be erratic and in the past I have used a dynamic resistor to absorb regen. Through no fault of my own we have wound up with a NEMA A motor on it (I read some of your comments about getting a cost reduction - exactly that!!) Anyway, as the motor reaches synchronous speed, the drive faults out on locked rotor current. The current tries to go through the roof. If I run at a reduced speed say 90% of sync speed, it runs fine. Only when I run towards 60HZ this happens. Can anybody help me understand why? Is this symptomatic of NEMA A? Should I be able to tweek the AFD into not being so clever and adjust characterisics to overcome this or am I screwed until I get a NEMA B on there?
Any help will be gladly received
Thanx
Thanx
