SolarMechE
- May 30, 2006
- 5
I work on a tracking solar concentrator that requires a motor to operate on a rooftop exposed to the elements for 15 years. I suspect that the only way for this to be possible is to seal the motor within an enclosure that mostly protects it from the environment.
Our current enclosure design is just a simple plastic box with an o-ring face seal between the cover and base of the box. Is that type of simple seal adequate?
The more complicated seal will occur on the motor shaft. Our motor is a NEMA 17 stepper that outputs around 100mNm of torque. It runs fairly slowly, around 50 RPM, but only for a few seconds at a time, once every minute or so (just enough to keep up with the sun). Cost is also a huge constraint for us. Anything over about $0.25 when purchased in quantities of several hundred thousand would most likely be out of the question. Are there any seals that meet these requirements?
The IP rating of the box is not something we're really specifying. All we care about is sealing it well enough to keep the motor running for 15 years. We've been under the assumption that there is no chance of sealing well enough to prevent moisture from entering the box, so condensation is something we are quite concerned about. We've been thinking about various solutions involving desiccant, but do not have a lot of knowledge of how to best use them.
Any thoughts or ideas on how to best implement this motor enclosure would be greatly appreciated.
