hi all,
I'm trying to simulate the welding process.
I've faced a problem...
the temperature of some nodes that the heat source is to pass them next, get values like -138'C.
and some times get to the absolute zero, and an error is the result.
this nodal points are infront of weld pool on the weld direction.
at the time the temp in the model, at such a point gets to the minimum, we have the maximum temp near 3000'c at point just near that. some times at the next node of the cubic element along the weld line.
you can see the image in attachment.
thanks for any attention,
