Hello All,
I've got a project that has about 45 feet of granular soil underlain by overconsolidated clay from 45 to 80, and then normally consolidated clay from 80 to 165 feet (rock at 165 feet). The project will include placement of about 3 feet of fill over the site, and then a new building.
Given the 3 feet of new fill, I'm estimating the negative skin friction on two pile types (steel H piles and precast concrete piles). I have load test data from an H pile project directly across the street.
My question is: is there any technical reason not to use the available load test data to determine "site specific" skin friction, and then apply that total skin friction load to my project as negative skin friction? In other words, use the static pile load test results that will provide me with positive skin friction and apply it as a negative to my site? Given that they would be piles end bearing on rock, the negative skin friction would be applied to the full length of the pile.
Additionally, intuitively it would seem excessive to apply the NSF to the full length of the pile (165 feet) given only 3 feet of fill (if using the nearby load test data, we would be talking about approximately 125 tons of negative skin friction), but given the overall area of the new fill and looking at stress distribution with depth, I expect there to be some amount of consolidation the full depth of the clay layer.
Any insight would be much appreciated.
