negative pressure air pipe wall thickness
guanghui an
CN
for negative pressure air pipe, how to calculate the wall thickness as per negative pressure value?
Are you referring to the gauge thickness for round ductwork under a certain negative pressure? The SMACNA duct construction manual provides the details on how to make that determination - which varies depending on a few other factors
Hi, GT-EGR, willard3,thanks for you reply, I will check the SMACNA duct construction manual
