Negative Numbers and Brackets
fb599
32
Can anyone tell me how to format a number to have brackets automatically in an Excel spreadsheet when the numbers are negative values please. This is a financial application however !
You should be able to specify that in the custom number formats, just like the ones that make negative numbers red.
TTFN
Using custom format, #,###.00;(#,###.00) produces the following:
500.2945 ----> 500.29
-52300.153 ----> (52,300.15)
You can manipulate the format by changing the number of #'s and 0's. The important part is #;(#).
Good luck!
jproj
Format cell, then click on number and then on how you want then negitive numbers to show up( in the lower left of the format pop up)
