Hello all, this is my first post.
I am currently trying to upload a database for a site I am working on however I constantly get the same error. My coding knowledge is close to nothing in relation to SQL.
I will provide the code that gives the error and the error in question:
"SQL-query:
CREATE TABLE mos_components(
id int( 11 ) NOT NULL AUTO_INCREMENT ,
name varchar( 50 ) NOT NULL default '',
link varchar( 255 ) NOT NULL default '',
menuid int( 11 ) unsigned NOT NULL default '0',
parent int( 11 ) unsigned NOT NULL default '0',
admin_menu_link varchar( 255 ) NOT NULL default '',
admin_menu_alt varchar( 255 ) NOT NULL default '',
OPTION varchar( 50 ) NOT NULL default '',
ordering int( 11 ) NOT NULL default '0',
admin_menu_img varchar( 255 ) NOT NULL default '',
iscore tinyint( 4 ) NOT NULL default '0',
params text NOT NULL ,
PRIMARY KEY ( id )
) TYPE = MYISAM
MySQL said: Documentation
#1064 - You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near 'option varchar(50) NOT NULL default '',
ordering int(11) NOT"
If anyone can help, I'd greatly appreciate.
Ederico.
"SQL-query:
PRIMARY KEY ( id )
) TYPE = MYISAM
Ederico.
