need two part files in one drawing sheet
ninerocket1
I need some basic drafting help.....I have 2 seperate part files I would like to put into one drafting sheet.
Jim Walker
Lorentson Mfg Southwest
Start a new file, bring in the two parts as assembly components, make drafting views as necessary.
Master model concept, as cowski suggests.
Hi, also you can use the layers to make visible on of the part or the other "visile in view" for this you must move part 1 on one layer and part 2 on other.
Visible in view can go along with master modeling.
Thanks to every one, I am using the visible in view...works great.....next time I will try the component method....once again..thanks
Jim Walker
