In the interest of adding some some more information regarding the addition of chloride in concrete, I submit the following quotations. Like any material or admixture, under the right circumstances, the addition of calcium chloride has a place in the construction industry.
Reference: Materials of Construction, 6th Edition by Lloyd F. Rader, John Wiley & Sons, Inc., 1967:
Page 413:
“The effect of adding SODIUM chloride to concrete cured at temperatures BELOW 32 degrees F is to REDUCE the freezing temperature and to retard the freezing of the concrete, thus permitting its setting and hardening. For curing BELOW 32 degrees F, the addition of UP TO 12 % by weight of mixing water INCREASES the concrete strength, but higher percentages are detrimental to strength. Approximately 1% of salt in the mixing water lowers the freezing point 1 degree F (0.55 degrees C). For curing at NORMAL temperatures, the addition of salt causes a DECREASE in the strength of the concrete. The integral use of CALCIUM chloride causes a more rapid rate of liberation of heat of hydration of the cement, thus promoting early strength development and thereby furnishing materially greater resistance of the concrete to the detrimental effect of low temperatures.” (Emphasizes are mine.)
Page 420:
“T.E. Stanton in a comprehensive series of long-time tests reported a definite increase in compressive strength at 1 year for Portland-cement concrete containing additions of calcium chloride up to 5 % by weight.” (T.E. Stanton: A Study of Calcium Chloride as a Strength Accelerator in Portland Cement Concrete, Proceedings of the Highway Research Board 1950, p. 232)
These statements pertain to the strength characteristics of the concrete and were made without reference to the effects that sodium and calcium chloride may have on the reinforcing steel or other embedded items. However, the addition of .5% to 2% calcium chloride to reinforced concrete that is not exposed to the weather has not been found detrimental. The finishing time of floor slabs is reduced considerably with the addition of calcium chloride and is used more than most engineers realize.
